I wasn’t aware that there are any new motherboards that don’t support PCI-E. The newest version 2.0 is backwards compatible (meaning you can plug in pcie 2 graphic card in pcie 1 motherboard)
this is 2nd time you say this. I assumed its 32 gigabytes (gb) first time i read it, and now i have to ask. 32gb is huge amount for system ram (unnecessary imho) and 32mb for graphic card is insufficient today, even low end cards have at least 64mb, afaik.
Imo, 8gb is more than enough for most work. 16gb might be cool in some situations. I know top end productions must use huge amounts of ram, but I didn’t get to fully utilize my 8gb. And that really depends on what you do. If you have highly complex characters with hair or huge amounts of grass, than yes, you will need 8+gb. If not, even 8gb is more than enough.
So i will need to find a PCI card between 200$ ans 500$. |
PCI graphic cards died some time before 1998. AGP took over about than and has ruled until 2004 when PCI-E was introduced. AGP is slowly but surely dying and PCI-E 1 is getting obsolete now too.
For less than 200$ you can buy THE best graphic card for 3d content creation, the aforementioned ATi/AMD HD3870. For rendering only system this is unnecessary, and you can get away with "HD2400pro" or less (if there is such thing as less expensive than that one (i think its 50$ or so)) since it has 0 impact on rendering times. Any graphic card will work with max. It only needs to be able to display video. It doesn’t even have to have to be able to accelerate 3d. That said, you’d be hard pressed to find such a card today.
Good luck. I hope this helps
