Hi is Maya Composite a plug-in for Maya?
Is it like Nuke?
I can't find it in the autodesk store.
I just saw it on an Autodesk tutorial on youtube and it looks interesting. Any information would be great.
Thanks for taking the time to reply.
I've got Maya 2013. Is the Composite accessable inside Maya 2013? If not, how can a get a copy of it?
its the same as 3ds Max its an optional install
DarrenP
Thanks, so I'll uninstall Maya 2013. Renistall it and look for Maya Composite.
Thanks for your help.
Hi, look I really hate going on about this, because it's so noobish and you must have better things to do with your time.
I put my Autodesk disc in and I just got this list of the contents on the disc. I don't know how to rerun the installer.
Can I just install 2014 and it will reinstall 2013 from the autodesk website, as that's all I'm liscenced to have, and during that process check the composite option?
Again, I'm sorry for my epic ignorance here.
Hi. After all that, I reran the installer and it says Composite is installed!
Is the attached png Composite? If not I'm not sure where to find it.
Thanks for all the help and time you've given me.
the default location should be here: C:\Program Files\Autodesk\Composite2014
DarrenP
