Solved by bibi23. Go to Solution.
@Anonymous wrote:
Our IT guys figured it out... My problem was "Software license check out failed, Error 2"
Here is what they did to resolve it:
There is a file in the ADLM directory under ALL USERS\application data\Autodesk\ADLM called Cascadeinfo.CAS that can get corrupted. Renaming this file caused a new one to get created and Max fired right up. You can look it up on the autodesk site about cascadeinfo errors. There was a .CPP file that could not be read in the adlm log under my profile and when I typed that into Google it lead me to an article on the cascade errors.
Hope this helps you guys!
in my computer, there is no application file in users folder, do you have any idea?
Welcome to the community..
You will not have a folder structure like that because that folder structure only exist in WIndows XP and you are reviewing a posting that is old... The file is actually located here C:\ProgramData\Autodesk\Adlm. Programdata is a hidden folder so you made need to adjust your viewing settings.
Mark Lancaster
& Autodesk Services MarketPlace Provider
I am install 3d max design 2013 And it not open give an error the software liciense failed error 20
Hello Everyone
I have lived the same error " The Software License Checkout Failed. Error 20 " with my 3ds max 2010 64 bit
This happened right after my windows 10 64 bit has updated automaticly. Before this windos update 3ds max were working fine...
Of course I have uninstalled the max and reinstall but never helped. Same error showed again.. Several days I was crazzy about this..
I havent realised 3Ds max were doesnt replace flex files with reinstall.. Therefore error was continuing.
Solution is this
Uninstall all the max with components and backburner.
Search "autodesk" word at C:\ drive and delete all the files what ever found.
Search " Flex" word at C:\ drive and delete all the files what ever found.
Reinstall the max and activate.. 3ds Max 2010 64 bit will fireup..
Enjoy
Hello Everyone
Solution is this
Enjoy
I followed all of your steps, but under standard tab I couldent find FLEXnet.
i have done all this option to fix my error "flexnet licensing service" and "Flexnet licensing service 64".
but its not working again the same error getting to me and i'm not able to use the software
I can confirm this error seems related to Flexnet- at least on our PCs. I went to C:\ProgramData\FLEXnet\ and deleted all the files- then restarted max and it worked.
