I was sent here by the Autodesk Education Community Support to get help with Maya crashing. i was also told These discussion groups are monitored by Autodesk Experts and they would be able to respond with precise information.
My problem is I posted and I have an online class in three hours and I haven't gotten any response. If there is a better way to get help faster PLEASE tell me.
Need more info here...
What are you doing prior to the crash?
What operating system are you running?
What are your hardware specs?
AREA is a mostly community supported forum, so in terms of trouble-shooting crashing and stabiilty issues - there's not a lot of us here that can offer in-depth support. I just happened to come across the post recently and noticed it had no replies...
It would be great if you could post the solution you arrived at for your crashing issue for future visitors though. AREA functions as much as a solution archive as it does a living/breathing user forum, so your input here could be valuable to others that run into the same issue.
As far as expanded support, there is also some very useful content over at http://knowledge.autodesk.com/support/maya
If you are in need of more dedicated solutions - you may want to look into an Autodesk Subscription: http://www.autodesk.com/support-offerings/overview
