My employer is sending me this computer to use for 3ds Max. I render images of single rooms that I have built with with wood mouldings for clients wood mouldings companies. I add furniture and anything else needed to make a livingroom look "real".
I could not put a computer together, hence the pre-assembled computer. Could someone take a look and tell me if this computer would work well for me or if it would struggle for the task I would give it.
Thank you so much!
1 Dell Precision,T7600,MT,1300W
1 Eight Core XEON E5-2665, 2.4GHz, 20M, 8 GT/s,Turbo+,Dell Precision T7600
1 32GB (4x8GB) 1600MHz DDR3 ECC RDIMM
1 Dell USB KB, English, WIN7/8, OptiPlex and Precision Desktop
1 3GB NVIDIA Quadro K4000 (2DP and 1DVI-I) (2DP-DVI and 1DVI-VGA adapter)
1 1TB,SATA,3.5",7200,32M
1 C1 SATA 3.5 Inch,1-4 Hard Drive,Dell Precision T7600
1 Windows 7 Professional,No Media, 64-bit,Fixed Precision, English
1 Windows 7 Label, OptiPlex, Fixed Precision, Vostro Desktop
1 Dell Client System Update (Updates latest Dell Recommended BIOS, Drivers, Firmware and Apps),Precision Desktop
1 Dell Data Protection Access, Precision Workstations
1 Dell MS111 USB Optical Mouse,OptiPlex and Fixed Precision
1 Rack Mountable Platform without Rails, Dell Precision R5500
1 PERC H310 SATA/SAS Controller for Dell Precision, T7600
1 Dell(TM) Precision Resource DVD contains Diagnostics and Drivers
1 8X DVD-ROM SATA,Data Only,Dell Precision T3600,T5600 and T7600
1 Dell Precision,T7600,1300W 85% Efficiency
1 Enable Low Power Mode for EUP Compliance,Dell Precision Desktop
1 Regulatory Label,Dell Precision T7600
1 PERC Controller, Dell Precision T7600
1 Energy Star Not Selected,Dell Precision Desktop
1 No Out-of-Band Systems MGMT,PWS T7600
1 NO RAID,Dell Precison Tx600
640-BBES 1 Dell Precision Performance Optimizer
I'd be happy with that, seems like a beast.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Thank you for your thoughts darawork.
Is a better video card more important or is a better processor more important?
Depends on your rendering engine choice; CPU for Scanline, MentalRay and vRay. GPU for iRay, Quicksilver and vRay RT. Both the CPU and GPU specified above seem fine for either at this stage.
Darawork
AutoDesk User
