Hello! Can someone help me to find a solution of my task?
Here is it: I have been working in 3ds max on two monitors, and I didn't give any attention in which monitor my tabs of 3ds Max are! But I have given my second monitor for the other person to use. And now I have found that my tabs of "Manage Layers" and "Slate Material Editor" are absent! They are on my second monitor area!
1). I cant drag it - windows doesn't allow me to move my cursor to second monitor area. I can't switch my priority of monitors, my system does not allow me to use two monitor options.
2). I have tried to reset my interface - and it's just... just reset 3ds Max.
3). I have tried to load 3ds Max standart UI Scheme, but it just load standart Max IU and leave all 3ds max tab's on its place, even leave it's size!
Would you be so kind to help me with this? Thanks!
Solved by Steve_Curley. Go to Solution.
Oh! Awesome! My cursor jumped to the left edge of the screen. And with the arrows keys, tabs finally showed on! Thank you!
