GeForce Cards start out with the fastest rendering, then add the quality from there (in terms of hardware rendering), and Quadro Cards start out with the best rendering, then add the speed from there. |
Nope. That is general misconception. They both have exactly same defaults. Both lines can be set up in exactly same way.
Only tangible difference is that there is a profile for 3ds max already present in the quadro drivers. For the geforece drivers, a new profile needs to be set up(less than 10sec of work, less if you click ok faster). It is set up exactly the same way it would for any other program.
You can always disregard individual profiles and set a global rule that would force aa/af in all applications. aa/af are the only real real reason one would use these presets at all.
Max 2009 does not allow aa on any of the cards.
For the best cost/effective hardware for max, please read my post here:
area.autodesk.com/forum/Autodesk-3ds-Max/installation---hardware---os/rendering-super-computer---help-and-advice-needed/#70544
Will there be any driver issues with XPx64? |
XP x64 is for what most drivers are primarily optimized when it comes to windowed directx. Its continualy the fastest subset of all drivers from both ATI and nVidia. Both recognize xp x64 as the pinnacle of the 3d world OS.
Subsequently, Vista 32 has the fastest dx10 drivers from both manufacturers, and Vista 64 traditionally has the worst of the bunch. Not buggy or anything like that, but up to 20% slower than XP x64 version.
but if you want reliability, buy a Quadro. |
Another common misconception.
I explained this too many times in these forums alone. Not 1% of actual difference in stability cannot be noted between the identical chips used on quadro/geforce cards.
I’m about to build a computer for myself, and the quadro is my choice. |
That’s sad to hear.
If you value your money, you should read this:
area.autodesk.com/forum/Autodesk-3ds-Max/3ds-max-through-2008/viewport-issues-with-maxtreme-10/Page-10/#48487
area.autodesk.com/forum/Autodesk-3ds-Max/autodesk-3ds-max--3ds-max-design-2009/viewport-visualization-problem/Page-10/#74854
good luck
