Hi, my problem is this
After running the installer shows me this message
This is the log file
2013/5/26:00:40:05 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/5/26:00:40:05 Beto PTTJ2004 Launch 2013/5/26:00:42:04 Beto PTTJ2004 === Setup ended === 2013/5/26:00:40:32 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/5/26:00:40:32 Beto PTTJ2004 Launch 2013/5/26:00:40:58 Beto PTTJ2004 PageOpen LaunchDialog 2013/5/26:00:48:26 Beto PTTJ2004 === Setup ended === 2013/5/26:00:48:47 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/5/26:00:48:47 Beto PTTJ2004 Launch 2013/5/26:00:48:47 Beto PTTJ2004 An instance of setup is already running. Only one instance of setup can run at a time.2013/5/26:00:50:29 Beto PTTJ2004 === Setup ended === 2013/5/26:01:02:56 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/5/26:01:02:56 Beto PTTJ2004 Launch 2013/5/26:01:02:56 Beto PTTJ2004 An instance of setup is already running. Only one instance of setup can run at a time.2013/5/26:01:03:19 Beto PTTJ2004 === Setup ended === 2013/5/26:01:04:10 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/5/26:01:04:10 Beto PTTJ2004 Launch 2013/5/26:01:04:29 Beto PTTJ2004 === Setup ended === 2013/5/26:01:06:51 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/5/26:01:06:51 Beto PTTJ2004 Launch 2013/5/26:01:06:51 Beto PTTJ2004 An instance of setup is already running. Only one instance of setup can run at a time.2013/5/26:01:06:53 Beto PTTJ2004 === Setup ended === 2013/5/26:01:07:11 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/5/26:01:07:11 Beto PTTJ2004 Launch 2013/5/26:01:07:19 Beto PTTJ2004 === Setup ended === 2013/7/31:18:33:03 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/7/31:18:33:03 Beto PTTJ2004 Launch 2013/7/31:18:33:20 Beto PTTJ2004 === Setup ended === 2013/7/31:18:33:09 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/7/31:18:33:09 Beto PTTJ2004 Launch 2013/7/31:18:33:20 Beto PTTJ2004 PageOpen LaunchDialog 2013/7/31:18:33:35 Beto PTTJ2004 PageOpen LicenseDialog 2013/7/31:18:33:38 Beto PTTJ2004 PageOpen ProductInfoDialog 2013/7/31:18:34:44 Beto PTTJ2004 PageOpen ProductSelectionDialog2 2013/7/31:18:34:55 Beto PTTJ2004 PageOpen FullProgressDialog 2013/7/31:18:34:55 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent 2013/7/31:18:39:39 Beto PTTJ2004 Install DirectX® Runtime Succeeded 2013/7/31:18:39:39 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/7/31:18:39:44 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2 2013/7/31:18:39:45 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/7/31:18:39:48 Beto PTTJ2004 PageOpen InstallCompleteDialog 2013/7/31:19:03:36 Beto PTTJ2004 === Setup ended === 2013/7/31:19:10:17 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/7/31:19:10:17 Beto PTTJ2004 Launch 2013/7/31:19:10:51 Beto PTTJ2004 === Setup ended === 2013/7/31:19:10:34 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/7/31:19:10:34 Beto PTTJ2004 Launch 2013/7/31:19:10:52 Beto PTTJ2004 PageOpen LaunchDialog 2013/7/31:19:12:43 Beto PTTJ2004 PageOpen LicenseDialog 2013/7/31:19:12:50 Beto PTTJ2004 PageOpen ProductInfoDialog 2013/7/31:19:13:33 Beto PTTJ2004 PageOpen ProductSelectionDialog2 2013/7/31:19:13:52 Beto PTTJ2004 PageOpen FullProgressDialog 2013/7/31:19:13:52 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent 2013/7/31:19:20:53 Beto PTTJ2004 Install DirectX® Runtime Succeeded 2013/7/31:19:20:53 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/7/31:19:20:56 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2 2013/7/31:19:20:58 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/7/31:19:20:59 Beto PTTJ2004 PageOpen InstallCompleteDialog 2013/7/31:19:41:04 Beto PTTJ2004 === Setup ended === 2013/8/1:13:49:15 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/8/1:13:49:15 Beto PTTJ2004 Launch 2013/8/1:13:49:27 Beto PTTJ2004 === Setup ended === 2013/8/1:13:49:19 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/8/1:13:49:19 Beto PTTJ2004 Launch 2013/8/1:13:49:28 Beto PTTJ2004 PageOpen LaunchDialog 2013/8/1:13:49:41 Beto PTTJ2004 PageOpen LicenseDialog 2013/8/1:13:50:06 Beto PTTJ2004 PageOpen ProductInfoDialog 2013/8/1:13:50:53 Beto PTTJ2004 PageOpen ProductSelectionDialog2 2013/8/1:13:51:02 Beto PTTJ2004 PageOpen FullProgressDialog 2013/8/1:13:51:04 Beto PTTJ2004 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart 2013/8/1:13:51:38 Beto PTTJ2004 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2013/8/1:13:51:38 Beto PTTJ2004 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart 2013/8/1:13:51:49 Beto PTTJ2004 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded 2013/8/1:13:51:49 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent 2013/8/1:13:56:16 Beto PTTJ2004 Install DirectX® Runtime Succeeded 2013/8/1:13:56:16 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/8/1:13:56:17 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2 2013/8/1:13:56:17 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/8/1:13:56:17 Beto PTTJ2004 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2013/8/1:13:56:17 Beto PTTJ2004 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2013/8/1:13:56:19 Beto PTTJ2004 PageOpen InstallCompleteDialog 2013/8/1:14:28:43 Beto PTTJ2004 === Setup ended === 2013/8/1:15:20:32 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/8/1:15:20:32 Beto PTTJ2004 Launch 2013/8/1:15:20:48 Beto PTTJ2004 === Setup ended === 2013/8/1:15:20:39 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/8/1:15:20:39 Beto PTTJ2004 Launch 2013/8/1:15:20:48 Beto PTTJ2004 PageOpen LaunchDialog 2013/8/1:15:20:52 Beto PTTJ2004 PageOpen LicenseDialog 2013/8/1:15:21:06 Beto PTTJ2004 PageOpen ProductInfoDialog 2013/8/1:15:21:37 Beto PTTJ2004 PageOpen ProductSelectionDialog2 2013/8/1:15:21:44 Beto PTTJ2004 PageOpen FullProgressDialog 2013/8/1:15:21:44 Beto PTTJ2004 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q 2013/8/1:15:21:51 Beto PTTJ2004 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2013/8/1:15:21:51 Beto PTTJ2004 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q 2013/8/1:15:22:20 Beto PTTJ2004 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2013/8/1:15:22:20 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent 2013/8/1:15:28:31 Beto PTTJ2004 Install DirectX® Runtime Succeeded 2013/8/1:15:28:31 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/8/1:15:28:31 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2 2013/8/1:15:28:32 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/8/1:15:28:32 Beto PTTJ2004 Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2013/8/1:15:28:32 Beto PTTJ2004 Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2013/8/1:15:28:35 Beto PTTJ2004 PageOpen InstallCompleteDialog 2013/8/1:15:30:35 Beto PTTJ2004 === Setup ended === 2013/8/1:15:47:07 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/8/1:15:47:07 Beto PTTJ2004 Launch 2013/8/1:15:47:15 Beto PTTJ2004 === Setup ended === 2013/8/1:15:47:10 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/8/1:15:47:10 Beto PTTJ2004 Launch 2013/8/1:15:47:15 Beto PTTJ2004 PageOpen LaunchDialog 2013/8/1:15:47:19 Beto PTTJ2004 PageOpen LicenseDialog 2013/8/1:15:47:29 Beto PTTJ2004 PageOpen ProductInfoDialog 2013/8/1:15:48:33 Beto PTTJ2004 PageOpen ProductSelectionDialog2 2013/8/1:15:48:45 Beto PTTJ2004 PageOpen FullProgressDialog 2013/8/1:15:48:45 Beto PTTJ2004 Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Beto\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/8/1:15:49:11 Beto PTTJ2004 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2013/8/1:15:49:11 Beto PTTJ2004 Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Beto\AppData\Local\Temp\vcredist_x64_2005.log"" " 2013/8/1:15:49:39 Beto PTTJ2004 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded 2013/8/1:15:49:39 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent 2013/8/1:15:57:49 Beto PTTJ2004 Install DirectX® Runtime Succeeded 2013/8/1:15:57:50 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/8/1:15:57:50 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2 2013/8/1:15:57:50 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/8/1:15:57:50 Beto PTTJ2004 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619 2013/8/1:15:57:50 Beto PTTJ2004 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2013/8/1:15:58:09 Beto PTTJ2004 PageOpen InstallCompleteDialog 2013/8/1:15:58:51 Beto PTTJ2004 === Setup ended === 2013/8/1:16:36:24 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/8/1:16:36:24 Beto PTTJ2004 Launch 2013/8/1:16:36:37 Beto PTTJ2004 === Setup ended === 2013/8/1:16:36:51 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/8/1:16:36:51 Beto PTTJ2004 Launch 2013/8/1:16:36:51 Beto PTTJ2004 An instance of setup is already running. Only one instance of setup can run at a time.2013/8/1:16:36:52 Beto PTTJ2004 === Setup ended === 2013/8/1:16:36:33 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/8/1:16:36:33 Beto PTTJ2004 Launch 2013/8/1:16:36:37 Beto PTTJ2004 PageOpen LaunchDialog 2013/8/1:16:36:42 Beto PTTJ2004 PageOpen LicenseDialog 2013/8/1:16:36:45 Beto PTTJ2004 PageOpen LaunchDialog 2013/8/1:16:38:29 Beto PTTJ2004 PageOpen LicenseDialog 2013/8/1:16:38:29 Beto PTTJ2004 PageOpen ProductSelectionDialog2 2013/8/1:16:38:43 Beto PTTJ2004 PageOpen FullProgressDialog 2013/8/1:16:38:46 Beto PTTJ2004 Installing Autodesk® 3ds Max 2013 SDK: TRANSFORMS="C:\Users\Beto\AppData\Local\Temp\_AIBABA.tmp\x86\Tools\MAXSDK\SDK_3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" INSTALLDIR="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/8/1:16:38:46 Beto PTTJ2004 Install Autodesk® 3ds Max 2013 SDK Failed Failure is ignored, Result=2 2013/8/1:16:38:46 Beto PTTJ2004 Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/8/1:16:38:46 Beto PTTJ2004 Install Network License Manager Failed Failure is ignored, Result=2 2013/8/1:16:38:46 Beto PTTJ2004 PageOpen InstallCompleteDialog 2013/8/1:16:47:04 Beto PTTJ2004 === Setup ended === 2013/8/1:17:03:52 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/8/1:17:03:52 Beto PTTJ2004 Launch 2013/8/1:17:04:11 Beto PTTJ2004 === Setup ended === 2013/8/1:17:04:06 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/8/1:17:04:06 Beto PTTJ2004 Launch 2013/8/1:17:04:11 Beto PTTJ2004 PageOpen LaunchDialog 2013/8/1:17:23:06 Beto PTTJ2004 PageOpen LicenseDialog 2013/8/1:17:23:24 Beto PTTJ2004 PageOpen ProductInfoDialog 2013/8/1:17:24:10 Beto PTTJ2004 PageOpen ProductSelectionDialog2 2013/8/1:17:24:13 Beto PTTJ2004 PageOpen FullProgressDialog 2013/8/1:17:24:14 Beto PTTJ2004 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart 2013/8/1:17:24:40 Beto PTTJ2004 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2013/8/1:17:24:40 Beto PTTJ2004 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart 2013/8/1:17:24:53 Beto PTTJ2004 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded 2013/8/1:17:24:53 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent 2013/8/1:17:27:59 Beto PTTJ2004 Install DirectX® Runtime Succeeded 2013/8/1:17:27:59 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/8/1:17:28:00 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2 2013/8/1:17:28:01 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/8/1:17:28:01 Beto PTTJ2004 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2013/8/1:17:28:01 Beto PTTJ2004 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2013/8/1:17:28:04 Beto PTTJ2004 PageOpen InstallCompleteDialog 2013/8/1:17:47:22 Beto PTTJ2004 === Setup ended === 2013/8/1:18:25:03 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/8/1:18:25:03 Beto PTTJ2004 Launch 2013/8/1:18:25:21 Beto PTTJ2004 === Setup ended === 2013/8/1:18:25:09 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/8/1:18:25:09 Beto PTTJ2004 Launch 2013/8/1:18:25:21 Beto PTTJ2004 PageOpen LaunchDialog 2013/8/1:18:25:23 Beto PTTJ2004 PageOpen LicenseDialog 2013/8/1:18:25:32 Beto PTTJ2004 PageOpen ProductInfoDialog 2013/8/1:18:26:17 Beto PTTJ2004 PageOpen ProductSelectionDialog2 2013/8/1:18:27:11 Beto PTTJ2004 PageOpen FullProgressDialog 2013/8/1:18:27:11 Beto PTTJ2004 Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Beto\AppData\Local\Temp\vcredist_x86_2005.log"" " 2013/8/1:18:28:26 Beto PTTJ2004 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded 2013/8/1:18:28:26 Beto PTTJ2004 Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Beto\AppData\Local\Temp\vcredist_x64_2005.log"" " 2013/8/1:18:28:43 Beto PTTJ2004 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded 2013/8/1:18:28:43 Beto PTTJ2004 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q 2013/8/1:18:28:52 Beto PTTJ2004 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded 2013/8/1:18:28:52 Beto PTTJ2004 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q 2013/8/1:18:29:01 Beto PTTJ2004 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded 2013/8/1:18:29:01 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent 2013/8/1:18:34:54 Beto PTTJ2004 Install DirectX® Runtime Succeeded 2013/8/1:18:34:54 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/8/1:18:34:55 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2 2013/8/1:18:34:56 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/8/1:18:34:56 Beto PTTJ2004 Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1619 2013/8/1:18:34:57 Beto PTTJ2004 Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619 2013/8/1:18:34:57 Beto PTTJ2004 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619 2013/8/1:18:34:57 Beto PTTJ2004 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2013/8/1:18:35:00 Beto PTTJ2004 PageOpen InstallCompleteDialog 2013/8/1:18:35:57 Beto PTTJ2004 === Setup ended === 2013/8/1:19:05:34 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/8/1:19:05:34 Beto PTTJ2004 Launch 2013/8/1:19:07:58 Beto PTTJ2004 === Setup ended === 2013/8/1:19:07:51 Beto PTTJ2004 === Setup started on PTTJ2004 by Beto === 2013/8/1:19:07:51 Beto PTTJ2004 Launch 2013/8/1:19:07:59 Beto PTTJ2004 PageOpen LaunchDialog 2013/8/1:19:08:28 Beto PTTJ2004 PageOpen LicenseDialog 2013/8/1:19:08:35 Beto PTTJ2004 PageOpen ProductInfoDialog 2013/8/1:19:10:05 Beto PTTJ2004 PageOpen ProductSelectionDialog2 2013/8/1:19:10:12 Beto PTTJ2004 PageOpen FullProgressDialog 2013/8/1:19:10:12 Beto PTTJ2004 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart 2013/8/1:19:10:25 Beto PTTJ2004 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded 2013/8/1:19:10:25 Beto PTTJ2004 Installing DirectX® Runtime: C:\Users\Beto\Documents\3ds Max 2013 x64 JP\3rdParty\DirectX\DXSETUP.exe /silent 2013/8/1:19:14:17 Beto PTTJ2004 Install DirectX® Runtime Succeeded 2013/8/1:19:14:17 Beto PTTJ2004 Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="C:\Users\Beto\Documents\3ds Max 2013 x64 JP\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 2013/8/1:19:14:19 Beto PTTJ2004 Install Autodesk Material Library 2013 Failed Installation aborted, Result=2 2013/8/1:19:14:20 Beto PTTJ2004 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2013/8/1:19:14:20 Beto PTTJ2004 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
Help me please!
Goto 3rd party folder and install all applications and your problem will be fixed. My problem was fixed by that method.
How do you sign in as an administrator? I can only see student/ faculty/ mentor as options.. Getting so fustrated with this, I literally cannot continue with my course until this gets sorted 😞
