Hy,
Recently instal 3dsmax 2014 and i have a problem with the dropdown menu in arch + design material editor. The dropdown menu is empty. Also I reinstal the software but the truble is the same. Also I have on my computer 3dsmax 2010 64bit and dont have any problem with mental ray or arch and design tempate ..
Solved by darawork. Go to Solution.
Try replacing your mrArchMaterial.ini with the one in the .zip in the sendspace link below.
Yours should be located at: C:\Users\[YourNameHere]\AppData\Local\Autodesk\3dsMax*\Year - 64bit\ENU\en-US\plugcfg
If that doesn't work, try renaming the ENU folder to ENU-temp and then restarting Max. That does a factory reset for your Max profile.
http://www.sendspace.com/file/q2ruqe
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Thanks a lot it works (the second suggestion-that rename the folder ENU)!
Thanks again!
Regards
Dean
hi im having the same problem of arch and design having no templetes i recently installed my 3ds max 2013 on windows 7 , ans also assigned renderer to mental ray please help me
