Installation & Licensing
Mental ray render - 'Arch and Design' template dropdown is not visible
3 REPLIES 3
deannina
1397 Views, 3 Replies
Hy,
Recently instal 3dsmax 2014 and i have a problem with the dropdown menu in arch + design material editor. The dropdown menu is empty. Also I reinstal the software but the truble is the same. Also I have on my computer 3dsmax 2010 64bit and dont have any problem with mental ray or arch and design tempate ..
3 REPLIES 3
darawork
in reply to: deannina
Try replacing your mrArchMaterial.ini with the one in the .zip in the sendspace link below.
Yours should be located at: C:\Users\[YourNameHere]\AppData\Local\Autodesk\3dsMax*\Year - 64bit\ENU\en-US\plugcfg
If that doesn't work, try renaming the ENU folder to ENU-temp and then restarting Max. That does a factory reset for your Max profile.
http://www.sendspace.com/file/q2ruqe
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
deannina
in reply to: darawork
Thanks a lot it works (the second suggestion-that rename the folder ENU)!
Thanks again!
Regards
Dean
utrocks044218
hi im having the same problem of arch and design having no templetes i recently installed my 3ds max 2013 on windows 7 ,  ans also assigned renderer to mental ray please help me
Administrator Productivity
