Installation & Licensing
Memory / texture problems.
2 REPLIES 2
139 Views, 2 Replies
Akk! I have this model: a castle I built. I've laid out UVs and begun to texture. I'm trying to test my texture. I create a file node, attach the test jpg, place2dTexture node, and connect the file node to (for now) a lambert, which I then drop onto my model. I get the following output:
Script Editor:
Dropped lambert2 onto polySurface31 //
// Error: Image conversion (to IFF) failed //
// Error: Free memory is low. Memory exception thrown //
When I start maya, I get this output in the output window:
Cause of Memory Exception
1705 Mb free mem
2048 Mb free swap
244 Mb size of a (?)
My system:
Athlon 64 X2 4200+
3 GB RAM
GeForce 7600 softmoded to Quadro FX 1700
The file's image size is 8000x8000.
The image will not display in the viewport on shade w/ texture settings, and upon render, the image is just black.
The files are not corrupt on the file system side.
It seems that SOMETHING is filling up my memory, but according to all my meters it isn't full.
2 REPLIES 2
Maybe the picture size is too large.
Check preferences - display. A default max text res is 4096.
Also 8000 is way too big and I doubt that you need it. 1024 or 2048 tops and If you want details to show in some close ups than you should make separate hi def textures that you would use when needed and again 4096 would be enough.
Administrator Productivity
