Hi guys,
my Maya 2014 don't recognize my Nvidia GPU, and instead use my integrated Intel HD GPU.
What shoul i do to force Maya to use mt Gtx560 instead Intel HD Gpu ?
I use the latest nvidia drivers btw.
Welll... we discovered that Maya does see the graphics card in slot #1, but only if it is feeding at least one of your monitors. We have MacPros, two Apple monitors, with nVidea Quadro 4000 cards as a second video card besides the original AMD that came with the Apple built workstations... the 4000's are in slot #1. Since the Mac version of the 4000 only has one each of DVI and DP ports and Apple monitors need a mini port to plug into... sometimes during setup both monitors get plugged into the AMD card by mistake and then the 4000 is ignored. You need two adapters to plug Apple monitors into the 4000, one being an active adapter. Other wise plug one monitor into the DP port using nVideas passive adapter that comes with the card. Then only display your Maya viewport in that monitor to take advantage of the expra ram and speed if you don't go the active adapter route to plug in the second monitor.
