First you need to know that for 12.3 you will need the following libraries :
libpng12.so.0
libtiff.so.3
Symlink of libssl.so.10 to libssl.so.1.0.0
libcrypto.so.10I've uploaded those libraries to my Google Drive to make the setup easier for me and others in the community.
Here's the link to the libraries :
https://docs.google.com/file/d/0B-CK...it?usp=sharingFire up the terminal. For this example I will be using "michael" as the user. Supposing the Autodesk Maya2014 is in your Documents, first we will "su -" command for root permission :
su -
password: ( then input your password )
Then we will have to navigate to the where the Maya installation folder is with the "cd" command :
cd /home/michael/Documents/Autodesk_Maya_2014_English_Linux_64bit
Then we will make the setup run with the "./" command like this :
./setup
You should have your autodesk license from the
http://students.autodesk.com/ web site and continue with the full installation.
After every library has been installed along with the maya setup itself you should will type inside the terminal:
maya
It should activate online and open application.
Now, here's the catch...
I did that sort of tutorial post so that everyone can install Autodesk Maya2014 on they're systems and tell me if it crashes after launching.
The application opens with a pop-up that I know it's normal because it's a student version and once you press the Continue button it crashes.
The terminal shows this :
maya encountered a fatal error
Signal: 11 (Unknown Signal)
Fatal Error. Attempting to save in /tmp/michael.20130602.1700.ma
QWidget::setWindowModified: The window title does not contain a '
' placeholder
Please if anyone gets around this let me know.
My computer specs are:
Asrock H55M-LE
Core i7 870
8GB DDR3 1600mhz
Nvidia GTX 550 ti
- Note* On this machine I swap hard drives and I have Autodesk Maya 2014 installed on Windows and it runs. After making the Opensuse instalation on the new HDD I just installed, all I did was update the system and install the nvidia drivers. I will try with the default nouveau drivers and post back on the results.
