Installation & Licensing
Maya 2012 crash on startup
10 REPLIES 10
Message 1 of 11
abdallahb
790 Views, 10 Replies
Dear Team,
 I've suddenly faced this Maya 2012 crashing on start up, I did uninstalled and Installed again but still the issue is there
10 REPLIES 10
Message 2 of 11
in reply to: abdallahb
If I were you I'd check to see if there are any driver updates for your graphics card.
Message 3 of 11
abdallahb
No, I haven't update it
Message 4 of 11
tony.su
Could you try this?
1.exit maya
2.delete or rename maya user setting folder
Windows
(Windows XP)
\Documents and Settings\<username>\My Documents\maya\2012
(Windows XP 64bit)
\Documents and Settings\<username>\My Documents\maya\2012-x64
(Windows 7)
\Users\<username>\Documents\maya\2012
(Windows 7 64bit)
\Users\<username>\Documents\maya\2012-x64
Mac OS X
/Users/<username>/Library/Preferences/Autodesk/maya/2012
Select Finder > Go > Go to Folder and type the directory path (/Users/<username>/Library/Preferences).
From the Terminal window, navigate to the Preferences directory and type open.
Linux (64-bit)
~<username>/maya/2012-x64
3.lunch maya, and select create default setting.
Tony Su
Product Support
Message 5 of 11
in reply to: tony.su
Dear Tony,
Is this something that's occurred due to a recent OSX update?
I'm having the same problem here with Maya 2011.
Ran it for years without issue, but it is now crashing on startup.
I have tried renaming the "prefs" folder in ../Autodesk/Maya/2011-x64/ but it still crashes. It does not get to an option to "Create default setting".
Any ideas or specific things to try?
Mike
Message 6 of 11
tony.su
o,I see.
When Maya 2011,2012,2013 or 2014 released, Mac OS 10. 9 didn't release yet. So in Maya system requirements list, there isn't Mac OS 10.9. And we couldn't test on Mac OS 10.9 at that time.
We don't know if there is any issue on Mac OS 10.9.
Tony Su
Product Support
Message 7 of 11
abdallahb
hi,
   thanks for your info, I had to downgrade mac to 10.8x make it work!!
Message 8 of 11
Tony,
Is there any possibility of this bug getting a hotfix?
Abdallahb,
Could you explain how you rolled back to 10.8x please? Unless it was via Time Machine?
Mike
Message 9 of 11
Hey guys, I am having a similar issue with 2014 on my Mac OSX Mavericks. It ran fine for a couple weeks then randomly started crashing, and now it will not even run. I get the command window and a "Stack Trace" error window. Very strange.
Message 10 of 11
abdallahb
Dear,
 sorry for late reply, about roll back, I just send my machines to our IT team, I haven't recive it back yet,
thanks
Message 11 of 11
shawn
Tony is there any way to get some actual help? I have a new HP zbook with a quadro and I just upgraded to win 8.1 JUST to see if Maya would run and it has the same issue of strating up and then the second I try and move the camera or create a shape the program freezes. I am trying to run Maya 2014 educational any Ideas is there any where to get more directed help than hoping someone gets back to you on the forums?
Tags (1)
Administrator Productivity
