Installation & Licensing
Maya 2008 Preferences to use all the cores in a Quad Core System
2 REPLIES 2
211 Views, 2 Replies
Hello All,
System specification is as below:
QUAD Xeon E5420 2.50Ghz Processors
8GB FBDIMM DDR2 800 REG ECC
80GB 7200rpm Module System Drive
Operating System: Windows XP Pro x64
3D App: Maya2008
Maya seems to drive 2 cores to 100%, while keep the other cores not being used.
Just wanted to know whether there is any preference settings in Maya 2008, where I can drive all the cores. OR ELSE
1) Have to re-install Maya 2008
2) System hardware is not compatible
Your help would be helpful.
Thank you
2 REPLIES 2
n8skow
rendering is about the only process that can use all your cores at the moment, though more features will be multi-threaded in the future...
you can set 'use all processors' in the batch render menu.
Just found out
1) When we render a scene from within Maya app, it uses all the cores (use all the CPU is checked in preference)
2) When we render using command line only 50% of the CPU on a system are used by default
3) In order to use all the CPU via command line rendering -mem 0 -rt 4 ( Quad Core/ 8 for 8 cores), then it uses up all the cores.
Thanks for the reply
Adarsh
Administrator Productivity
