Area :: Header
Meet the Experts Webinar
Learn how Black Forest Games rebooted the classic C64 platform game “Giana Sisters” from 1987 using Autodesk 3ds Max®.
Discussion Groups
Installation - Hardware - OS
Member
MaxStartUI.mnu is invalid!.... What?
1125 Views, 13 Replies
07-22-2009 03:59 AM
I had my copy of 3ds Max Design up and running fine for a couple of weeks then out of nowhere one day it displayed this message:
Invalid File
C:\Documents and Settings\Administrator\Local Settings\Application Data\Autodesk\3dsmax\2009 - 64bit\enu\UI\MaxStartUI.mnu is invalid!
What does this mean & what should I do?
I have no idea what this is about and have attempted a reinstall but there is no simple option to do this so rather than potential doing more damage I thought I'd ask for help.
I left this problem unattended for a few weeks because I have been busy with deadlines & had access to other copies through my institutions system. I would greatly like to get my personal copy up and running again though.
Any help would be greatly appreciated.
Marcus
ps I have attached a screenshot of the error...
Please use plain text.
Member
Re: MaxStartUI.mnu is invalid!.... What?
07-29-2009 06:15 AM in reply to: Marcus_Lee
Anybody....?
Surely someone has at least a clue what's up?
Active Member
07-29-2009 06:24 AM in reply to: Marcus_Lee
I read in another forum to delete the file solves this problem. Max is creating a new one.
Pete
Member
07-29-2009 07:49 AM in reply to: Marcus_Lee
This worked, I had run a few searches for this problem via google but came up with nothing so major thanks! :-)
New Member
arkijice
02-15-2010 01:40 PM in reply to: Marcus_Lee
Yeah! IThis worked, simply delete the file. many thanks!
New Member
Juliea_1
03-11-2010 03:38 AM in reply to: Marcus_Lee
Hi!
I have the same problem. Can you tell me what file I have to delete?
Moderator
Steve_Curley
03-11-2010 04:08 AM in reply to: Juliea_1
Read the first post - the full path to the file is in there.
Depending on your OS and Max version yours may be slightly different.
Max 4.2 through 2014 (SP5/Ext1), Composite 2014.
XP-64 (SP2). i5-3570K @ 4.4GHz, 8Gb Ram, DX9.0c.
nVidia GTX760 (2GB) (Driver 327.23).
New Member
3parch
06-30-2010 12:41 AM in reply to: Marcus_Lee
You should Delete this file MaxstartUI.mnu, i have to a Error same you!
Distinguished Contributor
syndicate5
05-20-2011 09:11 PM in reply to: Marcus_Lee
Ive deleted the file and it owrked but I also work with another program called RealFlow and it seems like since these two applications work together with importing/exporting meshes, it seems like it keeps corrupting it.
3ds Max 6.5 - Max 2014
Windows 8 Intel Core 2 Quad Q9400 2.13 GHZ
64-Bit, 8 GB RAM
Facebook: https://www.facebook.com/DM.3D.Artist
Website: http://dustinmoore.us
New Member
zainu
01-20-2012 04:02 AM in reply to: Marcus_Lee
I have same problem in 3d max 2008 32 bit MaxStartUI.mnu in not valid.
I can not see any enu folder and MaxStartUI.mnu I already search these file but not found.
give any solution. plz
