Installation & Licensing
MaxStartUI.mnu is invalid!.... What?
13 REPLIES 13
Message 1 of 14
6214 Views, 13 Replies
I had my copy of 3ds Max Design up and running fine for a couple of weeks then out of nowhere one day it displayed this message:
Invalid File
C:\Documents and Settings\Administrator\Local Settings\Application Data\Autodesk\3dsmax\2009 - 64bit\enu\UI\MaxStartUI.mnu is invalid!
What does this mean & what should I do?
I have no idea what this is about and have attempted a reinstall but there is no simple option to do this so rather than potential doing more damage I thought I'd ask for help.
I left this problem unattended for a few weeks because I have been busy with deadlines & had access to other copies through my institutions system. I would greatly like to get my personal copy up and running again though.
Any help would be greatly appreciated.
Marcus
ps I have attached a screenshot of the error...
13 REPLIES 13
Message 2 of 14
Anybody....?
Surely someone has at least a clue what's up?
Message 3 of 14
I read in another forum to delete the file solves this problem. Max is creating a new one.
Pete
Message 4 of 14
This worked, I had run a few searches for this problem via google but came up with nothing so major thanks! :-)
Message 5 of 14
Yeah! IThis worked, simply delete the file. many thanks!
Message 6 of 14
Hi!
I have the same problem. Can you tell me what file I have to delete?
Message 7 of 14
Steve_Curley
Read the first post - the full path to the file is in there.
Depending on your OS and Max version yours may be slightly different.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 8 of 14
You should Delete this file MaxstartUI.mnu, i have to a Error same you!
Message 9 of 14
syndicate5
Ive deleted the file and it owrked but I also work with another program called RealFlow and it seems like since these two applications work together with importing/exporting meshes, it seems like it keeps corrupting it.
3ds Max 6.5 - Max 2014
Windows 8 Intel Core 2 Quad Q9400 2.13 GHZ
64-Bit, 8 GB RAM
Facebook: https://www.facebook.com/DM.3D.Artist
Website: http://dustinmoore.us
Message 10 of 14
I have same problem in 3d max 2008 32 bit MaxStartUI.mnu in not valid.
I can not see any enu folder and MaxStartUI.mnu I already search these file but not found.
give any solution. plz
Message 11 of 14
Steve_Curley
Set the Windows Search to include hidden files and folders. It's in the Advanced options (on XP anyway).
Max 2016 (SP1/EXT1)
Message 12 of 14
DarrenP
there is also an article on it: http://area.autodesk.com/blogs/maxstation/a6_error_maxstartui_mnu_is_invalid
DarrenP
Message 13 of 14
I have same problem in 3d max 2008 32bit
but i can't see any MaxStartUI.mnu file
give me some solution
my email adress : szainali_89@yahoo.com
Message 14 of 14
Steve_Curley
The file is in a Hidden folder. Set the search and/or Explorer to "show hidden files and folders".
And please refrain from posting the same question multiple times within the same thread - once is sufficient.
Max 2016 (SP1/EXT1)
Administrator Productivity
