Show only
Search instead for
After installing SP1 on our working Max2009 64 bit installs, the authorization dialog box now appears as though they have been reconfigured from floating network license installs to standalone installs. I know there is a way to repair this in the registry but pretty sure this should not have happened....
In my opinion, the correct, long-lived solution is to redo the install correctly. A quick registry fix is the kind of thing that can cause mysterious problems later.
Check "Help | About" to confirm which license type you have.
Max2009 install was done by the book and 100% functional before the SP1 install. sorry if that was not more clear but thanks for the suggestion. just a quick edit to point others in similar circumstances: area.autodesk.com/forum/Autodesk-3ds-Max/autodesk-3ds-max--3ds-max-design-2009/max-2009-sp1-changes-network-license-to-standalone-was-ate-my-baby/
