Hi guys,
I wanted to know if there was a limit to the number of cores on a single machine running? For example, if I had a machine with 2 processors each having 9-12 cores (don't know if this exists yet), would Max have an issue with running with this configuration?
Solved by BenBisares. Go to Solution.
Personally I've seen Max working on systems with 48 threads (Blade server) and the elements of Max that are multithreaded work fine.
I have seen only one issue. mental ray will allocate available RAM equally to all threads. So the more threads you have the less RAM each thread will have. Example: Let's say you have 12GB of RAM available and a 6 core Intel i7 with Hyperthreading enabled (so 12 threads). mental ray will allocate 1GB of RAM to each thread. If you disable Hyperthreading you'll only have 6 threads so each one will get 2GB of RAM.
So imagine you have 48 threads so, 12/48 = 250MB of RAM per thread. Could be a problem with heavy scenes.
To be honest though that was the only time I saw a problem so I would say that you're safe at the moment.
Does this mean I should disable hyperthreading before rendering?
I have two 16 core processors and 64GB of RAM, so 32 threads. I _only_ work with large scenes. My renders average 16,000,000 polys. Since I first got this machine I've felt it renders slower than expected.
