Installation & Licensing
Max processor cores
3 REPLIES 3
framarz
647 Views, 3 Replies
Max processor cores
Hi guys,
I wanted to know if there was a limit to the number of cores on a single machine running? For example, if I had a machine with 2 processors each having 9-12 cores (don't know if this exists yet), would Max have an issue with running with this configuration?
3 REPLIES 3
BenBisares
in reply to: framarz
Personally I've seen Max working on systems with 48 threads (Blade server) and the elements of Max that are multithreaded work fine.
I have seen only one issue. mental ray will allocate available RAM equally to all threads. So the more threads you have the less RAM each thread will have. Example: Let's say you have 12GB of RAM available and a 6 core Intel i7 with Hyperthreading enabled (so 12 threads). mental ray will allocate 1GB of RAM to each thread. If you disable Hyperthreading you'll only have 6 threads so each one will get 2GB of RAM.
So imagine you have 48 threads so, 12/48 = 250MB of RAM per thread. Could be a problem with heavy scenes.
To be honest though that was the only time I saw a problem so I would say that you're safe at the moment.
Ben Bisares
in reply to: BenBisares
Does this mean I should disable hyperthreading before rendering?
I have two 16 core processors and 64GB of RAM, so 32 threads. I _only_ work with large scenes. My renders average 16,000,000 polys. Since I first got this machine I've felt it renders slower than expected.
framarz
Thanks for the response. Appreciate it 🙂
Administrator Productivity
