Hi, we just installed K4000's on our pc's and don't seem to be getting any performance increase from our previous quadro fx4800's. we primarily use 3ds Max 2013, are there any specific settings outside of the default that we should be using?
pc specs:
18gb ram
xeon w3550 3ghz dual core
win 7 x64
What are you using as your metrics in determining performance? Viewport FPS, render time, etc....
Hi Ben, having the same problem here. My main focus in upgrading from a GTX to a quadro is for the FPS for modeling. Can you suggest any hardware for this? thanks!
I can't really give any specific hardware options but I can give a guideline of what I personally would be looking for:
-If you're going to work with scenes with a high amount of polys and/or high res textures look for cards with as much RAM as possible
-If you're planning to use iray often then go for cards with the highest amount of CUDA cores. If your scenes will be complex too then large amounts of RAM is important too.
After that then I would just focus on what's in your budget range. To be honest the Geforce cards will offer you the highest bang for your buck. In general though the Quadro cards will carry the most amount RAM but some of the gaming cards these days aren't too far off.
Keep in mind that officially Autodesk supports workstation cards (and a smattering of consumer cards) (http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534&results=1&stype=graphic&produ...). If you have a subscription contract with us you'll only be able to get support with issues with cards on that list.
