Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
Did you mean:Ā
Floating License 2014 and 2015 not running in parallel
1 REPLY 1
229 Views, 1 Reply
currently being in the mirgration process from 2014 to 2015, I noticed a very anoying thing. I have a floating license, atm only used my local workstation (which the server is also runnging on). When I have Maya 2014 open  and try to open Maya2015 in parallel, I got a licensing error. Each version alone runs fine.
The expected behaviour is fine on node-locked machines.
What can I do?
Cheers
Felix
1 REPLY 1
dgorsman
Running different versions simultaneously will attempt to pull two licenses.  If you were to run two of the same version, or multiple products of the same version from a suite license, only one license would be pulled.
Administrator Productivity
