I just need a machine I can work in Maya on. Won't be running any additional programs, just Maya, not rendering too terribly much. Can someone tell me if this will or won't cut it:
I'm mostly worried about the CPU...
Solved by dgorsman. Go to Solution.
There's a couple of worries, more so if you are "working" rather than just "learning". One, is that a discrete video card? On-processor video is fine for app-games and movies but not so much for technical software. The hard drive isn't much to see either - 5400 RPM is slow, slow, slow; again, fine for generic stuff which Maya isn't. If you are limited to a conventional platter drive it should be 7200 RPM at a minimum BUT you should be looking at a decent sized solid state drive instead.
Thanks for the feedback! I've decided to just do a desktop. For the price, I'll get a better system. Now trying to decipher "Intel P4000 graphics." AHHH TECHNICAL!! 🙂
