I installed Autodesk Maya on my linux mint 14 kde version....
it works fine with everything,
until
I load jpeg texture or jpeg file to any place.
my maya crashes without any pop up error, but it shows
fatal error 11 in my terminal.
I search at many places and found that it is happening due to qt plugins, coz maya runs its GUI using qt.
I mailed qt team, but they are not responding well.
I install libjpeg62 package as some forums said, but that thing also do not work.
Hope, Autodesk team has some solution for this.
I like to autodesk products on my linux os. coz it gives best performance.
Thank you. hope i will have get solution for that
I think its because maya requires a library called libpng or libpng12. Try doing sudo apt-get install libpng or sudo apt-get install libpng12
Hope that helps!
hey man,
I installed that libpng liberary but still crashes.....
may be, it also required to preload in maya2014 script.....but i have to find its location.
thank you.
does anyone of you have this same problem ?
Not necessarily. I've only used gnome based distros in the past. Now I'm using openbox.
Did you add the line I told you to your maya2014 script file?
it somehow worked.
i try to change the libtiff links to other file and it works fine 🙂
great.
i was looking for this from very long time.
i tried to symbolic link
ln -s /usr/lib/x86_64-linux-gnu/libtiff.so.4.3.6 /usr/lib/libtiff.so.3
and add
"find this line in the file:
setenv LIBQUICKTIME_PLUGIN_DIR "$MAYA_LOCATION/lib"
and add the next line as a new line:
setenv LD_PRELOAD /usr/lib/x86_64-linux-gnu/
libjpeg.so.62
thank you very much all of you. 🙂
hi....
i have using myself made guide to install autodesk maya on debian based systems, ubuntu.
i have attached file for basic package requirements and method to install.
this are links for bash files...for some maya versions. 🙂
https://drive.google.com/folderview?id=0B0rPdzVEM38VMUtFOXpEQUJEbnM&usp=sharing
have fun.
