Installation & Licensing
Autodesk Maya 2014 crash on startup
9 REPLIES 9
Message 1 of 10
2075 Views, 9 Replies
Dear all,
im new to this forum so dont blame me if im not doing the right way. I searched for an linux forum here but was not able to find one so im posting in the general forum.
If there is a linux forum please tell me that im in the wrong place and maybe move it to the corect subforum.
I need some help for my Maya installation on my ubuntu linux maschine. Installation went well but im not able to start maya. The splash screen is loading fine but right after the splash screen maya crash back to the desktop.
At first start up i got the following terminal output:
maya
maya encountered a fatal error
Signal: 11 (Unknown Signal)
Fatal Error. Attempting to save in /usr/tmp/aki.20130917.1315.ma
Segmentation fault (core dumped)
As im not recieved all informations i needed i enabled DEBUG:
export MAYA_DEBUG_ENABLE_CRASH_REPORTING=1
maya
Stack trace:
  /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f27ebde64a0]
  xcb_glx_get_string_string_length
  /usr/lib/x86_64-linux-gnu/libGL.so(+0x404d4) [0x7f27c782f4d4]
  /usr/lib/x86_64-linux-gnu/libGL.so(+0x3df2c) [0x7f27c782cf2c]
  GLFunctionTable::populate()
  GLStartupContext::GLStartupContext(WindowWrapper const&, __GLXcontextRec*)
  OGLRenderBackEnd::createResourceContext(WindowWrapper const*, void*)
  T3dView::updateViewingParameters()
  TidleRefreshCmd::refreshBaseRender(T3dView*, bool, bool, TdisplayAppearance, bool, bool, bool)
  TidleRefreshCmd::refresh(T3dView*, TdisplayAppearance, bool, bool, bool, bool, TrefreshType, bool, bool)
  TtoolRefresh::refreshFast(T3dView*, TrefreshType)
  T3dView::doUpdate(Tevent const&)
  T3dPort::resize(Trect const&)
  QmayaGLWidget::resizeGL(int, int)
  Qmaya3dWidget::resizeEvent(QResizeEvent*)
  QWidget::event(QEvent*)
  QmayaGLWidget::event(QEvent*)
  QApplicationPrivate::notify_helper(QObject*, QEvent*)
  QApplication::notify(QObject*, QEvent*)
  QmayaApplication::notify(QObject*, QEvent*)
  QCoreApplication::notifyInternal(QObject*, QEvent*)
  QWidgetPrivate::sendPendingMoveAndResizeEvents(bool, bool)
  QWidgetPrivate::show_helper()
  QWidgetPrivate::showChildren(bool)
  QWidget::setVisible(bool)
  TiceControlBaseCmd::doEditFlags()
  TelfLayoutBaseCmd::doEditFlags()
  TelfPaneLayoutCmd::doEditFlags()
 Where
 and
 seems to be my problem...
Im not able to interpret both messages exactly. The only thing i know is that it has be something with my GPU-Driver and need some help here
Some system informations below:
lspci
07:00.0 VGA compatible controller: NVIDIA Corporation GK104 [GeForce GTX 690] (rev a1)
07:00.1 Audio device: NVIDIA Corporation GK104 HDMI Audio Controller (rev a1)
08:00.0 3D controller: NVIDIA Corporation GK104 [GeForce GTX 690] (rev a1)
08:00.1 Audio device: NVIDIA Corporation GK104 HDMI Audio Controller (rev a1)
uname -r
3.5.0-40-generic
dpkg -l | grep nvidia
ii  nvidia-319                                319.32-0ubuntu0.0.1                                NVIDIA binary Xorg driver, kernel module and VDPAU library
ii  nvidia-319-dev                            319.32-0ubuntu0.0.1                                NVIDIA binary Xorg driver development files
ii  nvidia-common                             1:0.2.44.2                                         Find obsolete NVIDIA drivers
rc  nvidia-current                            304.88-0ubuntu0.0.2                                NVIDIA binary Xorg driver, kernel module and VDPAU library
rc  nvidia-current-updates                    304.88-0ubuntu0.0.1                                NVIDIA binary Xorg driver, kernel module and VDPAU library
rc  nvidia-experimental-310                   310.14-0ubuntu0.3                                  Experimental NVIDIA binary Xorg driver, kernel module and VDPAU library
ii  nvidia-persistenced                       319.23-0ubuntu1~xedgers~precise1                   Load the NVIDIA kernel driver and create device files
rc  nvidia-settings                           304.88-0ubuntu0.0.2                                Tool of configuring the NVIDIA graphics driver
ii  nvidia-settings-319                       319.32-0ubuntu0.0.1                                Tool for configuring the NVIDIA graphics driver
rc  nvidia-settings-experimental-310          310.14-0ubuntu0.1                                  Tool for configuring the NVIDIA graphics driver
rc  nvidia-settings-updates                   304.88-0ubuntu0.0.2                                Tool of configuring the NVIDIA graphics driver
9 REPLIES 9
Message 2 of 10
warnold1
you have the right idea...   for whatever reason, Maya is not liking the Nvidia driver installation/xcb/glx
its not able to create its initial OpenGL contexts
if you run glxinfo,  what is the info for the segments below.  don't need all of the extensions or visuals
name of display: lnx-tsmaya64-main:0.0
display: lnx-tsmaya64-main:0 screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: Quadro FX 3800/PCIe/SSE2
OpenGL version string: 3.3.0 NVIDIA 325.08
OpenGL shading language version string: 3.30 NVIDIA via Cg compiler
OpenGL extensions:
 that will give some background info
the location of the crash
has google references for other applications having crashes with it. what version of Ubuntu are you using
Wayne Arnold
Developer
Message 3 of 10
Thanks for your help,
i splitted the infos given by glxinfo so i dont recieve the bunch of information stuff
glxinfo | grep OpenGL
OpenGL renderer string: GeForce GTX 690/PCIe/SSE2
OpenGL version string: 4.3.0 NVIDIA 319.32
OpenGL shading language version string: 4.30 NVIDIA via Cg compiler
OpenGL extensions:
glxinfo | grep glx
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
glxinfo | grep render
    GL_NV_conditional_render, GL_NV_copy_depth_to_color, GL_NV_copy_image,
    GL_NV_path_rendering, GL_NV_pixel_data_range, GL_NV_point_sprite,
    GL_NVX_conditional_render, GL_NVX_gpu_memory_info, GL_NVX_nvenc_interop,
Im running Ubuntu 12.04 LTS since a while now coming from openSUSE.
So it seems that i have to step back to another NVIDIA driver version?!
Anyway i also got trouble with Softimage but i guess that will be the same problem as wih maya.
Message 4 of 10
Just to inform you with driver version 304 maya runs fine:
ii  nvidia-304                                304.88-0ubuntu0.0.3                                NVIDIA binary Xorg driver, kernel module and VDPAU library
ii  nvidia-settings-304                       304.88-0ubuntu0.0.3                                Tool for configuring the NVIDIA graphics driver
So the last thing i wanted to know is where i can set the standard maya app directory. Maya normally set up all directories in /home/yourUSER/maya but i want to change that to another path.
Is there a quik way i can do that?
Message 5 of 10
warnold1
Set the environment variable MAYA_APP_DIR to the path you want to use
Sent from my iPad
Wayne Arnold
Developer
Message 6 of 10
Can i set it in Maya.env? Refer to the online documentation this is not possible and i have to set it in the OS! Well that seems to be a stupid question but how can i set it outside Maya.env?
Message 7 of 10
warnold1
Setting environment variable in bash is via the export command
Before launching Maya
export MAYA_APP_DIR=/some_path
maya
This can be put into a shell script file say maya2014
You run this shell script file instead of the "maya" shell script
Or put the export command into you local start up .profile to be set by default
Wayne Arnold
Developer
Message 8 of 10
First of all thanks a lot Warnold for your help.
I edited my maya launcher directly and changed
Exec=/usr/autodesk/maya/bin/maya
 to
Exec=env MAYA_APP_DIR=/home/yourUSER/yourFOLDER/maya /usr/autodesk/maya/bin/maya
So now my maya folder is in the right path i want to use. But there must be also an variable for getting the Adlm folder also into that directory?
Message 9 of 10
warnold1
I don't understand the reference to the Adlm directory
Wayne Arnold
Developer
Message 10 of 10
Well to me it seems that Adlm folder seems to be set from adskflex during the startup from maya.
The folder is complete empty. Deleting doesnt help as maya replace it during the next startup.
I was wondering if there is a related variable to set Adlm to another path like MAYA_APP_DIR fpr the maya folder.
Administrator Productivity
