So my problem is pretty simple..whenever i click the modifier list with an object selected 3dsmax 2014 instantly crashes.This problem occured recently.the program was factioning normaly with the moddifier list before
I have tried the following:
repairing 3dsmax
reinstalling (these are the options i didnt manualy uninstall it and reinstalled it)
reinstalling my video card drivers
install a 3dsmax service pack 3
This is pretty annoying and i cant edit anything without having it to crash
Plz someone help :C
note: sorry if thats the wrong place to post that
Solved by Steve_Curley. Go to Solution.
So i did check in my appdata the only thing i found was an autodesk folder with a 3dsmax folder in it.I renamed..max did make a new one but it didnt solve anything.I also did change the setting in folder options so it shows hiden files but still dint find anything relevant Sorry if iam doing something wrong 3;
note: found a tutorial on how to fix corupted files so it may help..
Thank you very much i wouldnt have thoiught searching in the appdata folder,the problem was actually the 3dsmax.ini file i just deleted it and max remade it..now it works as it normaly did 😄
