Installation & Licensing
173 Views, 2 Replies
3ds Max 8 Help
For some reason and all of a sudden, I cannot access the Environment portion under the Render drop down in 3ds Max 8. I tried to fix the problem with the install disc. So then I uninstalled and re-installed the program. Still cannot access it. Any help would be greatly appreciated.
2 REPLIES 2
Steve_Curley
This is the wrong forum for that question as it's not hardware / OS related. There's a specific one for older versions (3ds Max through 2008).
Rename your 3dsmax.ini or edit it as per this thread. Ignore the link - the location was different in Max 8 (in the installdir IIRC).
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
I apologize for placing this in the wrong section. The instructions worked, thank you very much.
Administrator Productivity
