Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
widget not display in the Toolbar
3 REPLIES 3
swimming123
1558 Views, 3 Replies
I try to create a JS, xml file and copy to the right location under fusion/widgets folder; Added the widget into ToobarVertical, but the widget did not show. Probaly something wrong. Anyone can give me some suggetion?
3 REPLIES 3
in reply to: swimming123
Did you declare the appropriate widget in your the WidgetSet portion of the Flexible Layout document?
- Jackie
swimming123
I just use the InvokeURL widget (js and xml) and modified it. because I need create a point layer using OpenLayer, then pass the lot/lat value of point to server side and do the query. So I delete the selection part, binded the digitize a point function with the widget. I didn't check the WidgetSet part in ApplicationDefinition file. Is this the right way?
Hi, i did something similar. I created a widget to invoque js from this i did a http request to server and the server side (C#.net) response the result that i wanted.
