when we login Infrastructure Map Server - Site Administrator--> Manager Servers-->Configure Services, we can set session timeout(seconds): 1200. I did a test, set session timeout 60 seconds, then after 60seconds, there's nothing affect for my map dispaly, widgets functions. Can I set somewhere, for example I can close the Map window or Close the Application to match my setting in .NET Global file setting: session timeout, web will log out? Thank you.
You could inject the following javascript into your page
window.setTimeout(<?= $timeout ?> * 1000, function() { alert("Your session has ended. Goodbye!"); window.close(); });
Where $timeout is the value of MgSite.GetSessionTimeout()
- Jackie
