Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
render map image in png8
2 REPLIES 2
778 Views, 2 Replies
we are using MGE 2010.
In order to reduce image size we changed
OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG to OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG8,
Image size reduced from 500k to 100k, but the image quality is bad. So we changed OPERATION=GETMAPIMAGE&FORMAT=PNG8 and the image quality is good enough(image size 100k).
please see attached imge
png_getMapImage: OPERATION=GETMAPIMAGE&FORMAT=PNG8
png: OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG
png8: OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG8.
GETDYNAMICMAPOVERLAYIMAGE operation has more parameter to use and can render selection sepeartely. Beside this one,is any difference as these two operation rendering image?
thanks!
Nick
2 REPLIES 2
dswilson
I don't believe GETDYNAMICOVERLAY processes base layers for tiled maps, hence the name. GetMapImage will process both.
Dave
We didn't use tiled maps.
We changed the function
function RequestMapImage(reqId, viewParams)
from
//url = webAgent + "?OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG8&VERSION=2.1.0&SESSION=" + sessionId + "&MAPNAME=" + encodeComponent(mapName) + "&SEQ=" + Math.random() + "&CLIENTAGENT=" + encodeComponent(clientAgent) + "&BEHAVIOR=2";
to
url = webAgent + "?OPERATION=GETMAPIMAGE&FORMAT=PNG8&VERSION=2.1.0&SESSION=" + sessionId + "&MAPNAME=" + encodeComponent(mapName) + "&SEQ=" + Math.random() + "&CLIENTAGENT=" + encodeComponent(clientAgent) + "&BEHAVIOR=2";
the getMapImage operation gets image much better that getDynamciMapOverLayImager in png8 fromat(same size).
also, we try the image format in jpeg.
why?
nick
