I followed the import instructions included in the 2012 help file.
I backedup up, and restored the repositories in 2010, and then copied them over to 2012.
When I run the SetupRepositoryindices.bat, it gives me this output, with a DBXML has stopped responding error, 3 times:
Attempting to join environment: C:\Program Files\Autodesk\Autodesk Infrastructur
e Map Server 2012\RepositoryAdmin\..\Repositories\Session
Unable to join environment C:\Program Files\Autodesk\Autodesk Infrastructure Map
Server 2012\RepositoryAdmin\..\Repositories\Session, creating a DB_PRIVATE envi
ronment
SetupRepositoryIndices.Script:1: openContainer failed, Error: MgSessionResourceC
ontents.dbxml: container file not found, or not a container
--- Setting up Site repository indices ...
e Map Server 2012\RepositoryAdmin\..\Repositories\Site
Joined existing environment
Adding index type: edge-element-equality-string to node: {}:Name
--- Setting up Library repository indices ...
e Map Server 2012\RepositoryAdmin\..\Repositories\Library
Adding index type: node-element-equality-string to node: {}:ResourceId
Adding index type: node-metadata-substring-string to node: {http://www.sleepycat
.com/2002/dbxml}:name
Adding index type: node-metadata-equality-double to node: {http://www.autodesk.c
om/MapGuide/Resource/Metadata}:Depth
Adding index type: node-metadata-equality-string to node: {http://www.autodesk.c
om/MapGuide/Resource/Metadata}:Owner
Adding index type: node-element-presence-none to node: {}:Metadata
C:\Program Files\Autodesk\Autodesk Infrastructure Map Server 2012\RepositoryAdmin>
The three red lines are where it seems to crash.
This is the error code that pops up when DBXML.EXE crashes.
Problem signature:
Problem Event Name: APPCRASH
Application Name: dbxml.exe
Application Version: 0.0.0.0
Application Timestamp: 4d709422
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7601.17725
Fault Module Timestamp: 4ec4aa8e
Exception Code: c0000005
Exception Offset: 0000000000053332
OS Version: 6.1.7601.2.1.0.274.10
Locale ID: 4105
Additional Information 1: add8
Additional Information 2: add89ebfcb1e4ee601913780718d8f3e
Additional Information 3: c08d
Additional Information 4: c08d6a2ef71a4544caf2b79187525492
This is a Windows Server 2008 R2 64-bit, 4GB Ram, Virtual Server.
Just to test, I restored the "default" repositories, and I still had the same crashes.
Thanks for any help.
