Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
674 Views, 1 Reply
overview maps
hi, i want to create an overview map into basic web layout .have you got any idea please
1 REPLY 1
gluckett
This is a tricky one.
  1.   I would create a popup window or an IFRAME with a map inside.
  2. The map I would use is an OpenLayers.org map.
  3. I would set up event hooking in the MAIN map with http://trac.osgeo.org/mapguide/wiki/CodeSamples/JavaScript/AJAXViewerEventHooking to watch the map and send extents to the overview map.
  4. If you wanted to get really tricky, you can draw a box using the OpenLayers.org API using the extents sent from step 3.
regards
gordon
