You're not using MapGuide 6.5 then, you are using MapGuide Enterprise. My
workflow still somewhat applies, but the underlying programming code will be
significantly different. You won't need to create a temporary redline
object if you already know the lat,lon coordinates you are using. In this
case, you can use the FDO API to do a spatial query against the desired
layer feature source based on an envelope you compute from your points,
create the selection set object (which will be on the server) from the
returned query results, then refresh the map with the client JavaScript API.
The developers guide only has PHP examples. I don't know if they are
planning to produce an equivelent .NET and Java guide. The downloadable
sample application from the OSGeo site at
https://mapguide.osgeo.org/servlets/ProjectDocumentList?folderID=10&expandFolder=10&folderID=36
are available in all 3 languages, however.
Andy
wrote in message news:5268748@discussion.autodesk.com...
I can kind've see how to go about doing this...however when I look at the
developers guide I always only see examples for .php. Is there any way to
do this stricly in javascript or C# in and .aspx page from the task frame?
