hello everyone.
i am working with the mobileviewer in AIMS2013, but i want to pass the map using post and not inside the URL (to keep the path hidden from the user)
sadly, whenever y try to add asp.net funtionality (c#) i got this nasty message (firefox web debug)
Request URL:
http://localhost/Default.aspx/localized/en.json
Request Method:
GET
Status Code:
HTTP/1.1 404 Not Found
as you can see, this takes the page name instead of the folder, because of this is not able to find the .json files.
i tried using the non compressed version of the mobileviewerSF.js, tried to hard-code the correct path, without success.
you can see the error in the following image.
is there a way to solve this problem? i was contemplating to embed the mobileviewerinside an iframe too, but this approach has another issues of its own (lack of iframe flexibility among devices is one of them).
i also saw this thread http://osgeo-org.1560.n6.nabble.com/en-json-error-in-mobile-viewer-td4182802.html but after adding the .json mime type the problem keeps appearing.
i dont know if anyone of you had any similar problem or know how to solve it, i would be really thankful if you can help me, or point me on a path that could solve my problem.
thank you for your help,
best regards,
Wilson H
