Hello respected members autodesk, using a web interface topobase error "failed to check out a license with AdLM code: 20." The problem is this: a user1 has gone web interfase, but user2 can not enter, an error occurs:failed to check out a license with AdLM code: 20
Tell me please how to configure the system so that users can logon in web interface?
Thanks!
Definitely a strange one.
Have you tried these examples?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13894457&linkID=9242778
Or service pack updates?
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242779#section1
For faster responses concerning Autodesk licensing issues, please post your questions in the Installation and Network Licensing user forum here:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Thank you for your reply, unfortunately your answer did not help us, we do not have the server file CascadeInfo.cas most likely this is due to licenses on the server, we have the settings you can use only one license, but no such license web properties Requests from the same user/ host do not consume a new license.
