Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
error 404 when trying to access en.json from mobileviewer using .net
1 REPLY 1
1157 Views, 1 Reply
hello everyone.
i am working with the mobileviewer in AIMS2013, but i want to pass the map as a post and not as a get through a map catalog (to keep the path hidden from the user)
sadly, whenever y try to add asp.net funtionality (c#) i got this nasty message (firefox web debug)
Request URL:
http://localhost/Default.aspx/localized/en.json
Request Method:
GET
Status Code:
HTTP/1.1 404 Not Found
as you can see, this takes the page name instead of the folder, because of this is not able to find the .json files.
i tried using the non compressed version of the mobileviewerSF.js, tried to hard-code the correct path, without success.
you can see the error in the following image.
is there a way to solve this problem? i was contemplating to embed the mobileviewerinside an iframe too, but this approach has another issues of its own (lack of iframe flexibility among devices is one of them).
i also saw this thread http://osgeo-org.1560.n6.nabble.com/en-json-error-in-mobile-viewer-td4182802.html but after adding the .json mime type the problem keeps appearing.
i dont know if anyone of you had any similar problem or know how to solve it, i would be really thankful if you can help me, or point me on a path that could solve my problem.
thank you for your help,
best regards,
Wilson H
1 REPLY 1
i tried to replace this script
var locale = mobileViewer.getQueryParam('locale');
if (locale != null && locale.length > 0) {
options.locale = locale;
passing as parameter the url of the json file but without sucess.
i only want to pass post requests to the mobileviewer (so the map path is not in the URL).
hope anyone can help me with this.
best regards.
Wilson H
