Infrastructure Map Server General
Member
jane911
Message 1 of 5 (1,231 Views)
could not select any object into my layer
1231 Views, 4 Replies
10-06-2010 07:25 AM
Hi ,
I'a developping an apllication with autodesk mapguide entreprise 2010 and sql server2008.
mydataconnection come from sql viewer so i couldn't selct any feature into my layer .
please help
Member
Message 2 of 5 (1,222 Views)
Re: could not select any object into my layer
10-15-2010 11:41 PM in reply to: jane911
Jane,
A few questions, is this a SQL Spatial database?  Also, I'm not sure what is the problem, are you not able to see any features in your map or are you not able to select them but you can see them.
Manoj
New Member
LoriBerry
Message 3 of 5 (814 Views)
11-15-2011 08:19 AM in reply to: jane911
I am also having issues with selecting features that have been loaded up from a spatial database (SQL Server 2008). Is this a limitation to Mapguide Enterprise?
Valued Mentor
Message 4 of 5 (806 Views)
11-16-2011 05:09 PM in reply to: LoriBerry
It's more a limitation of views.
Can MapGuide detect the identity properties from your view?
Because: No identity properties = unselectable layer
If that is the case, you have either re-consider the design of your view or to employ using a FDO schema override to say that [this column in this view is unique so use that as the identity property]
http://themapguyde.blogspot.com/2010/08/using-fdo-schema-overrides.html
http://themapguyde.blogspot.com/2010/09/using-fdo-schema-overrides-redux.html
- Jackie
New Member
Message 5 of 5 (755 Views)
04-06-2012 08:22 PM in reply to: jackie.ng
Finally I found the solution to my problem. Thanks for sharing
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
