This isn't dowload friendly, but is accesible online:
http://mapguide.osgeo.org/files/mapguide/docs/webapi/index.html
If you want a local copy, you have to do a custom install of the web
extensions and then manually choose to have the API documentation installed.
Given it's small footprint, why this isn't part of the default install is
beyond me........
Andy
"Paul"
wrote in message
news:5526323@discussion.autodesk.com...
thanks I got it to work,
you pointed me in the right direction.
but I can't find a downloadable version of the API
"Andy Morsell" wrote in message
news:5518394@discussion.autodesk.com...
See the MgCoordinateSystemTransform class in the API documentation.
There's an example of doing what you are asking in the section on the
Transform method (the Transform(MgCoordinate) listing).
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
"Paul" wrote in message
news:5518029@discussion.autodesk.com...
When creating a point using "CreateCoordinateXY()" can mapguide do a
coordinate conversion to the current map coordinate system.
For example, I am using a geocoder utility that returns lat/lon data but the
map is in another coordinate sysem in metres.
There is "CreateCoordinateXYM()" with "measure" as the third parameter but I
don't know how to use it.
thanx
