Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
connecting to an access database (mapserver 2013)
3 REPLIES 3
mfernandes
1768 Views, 3 Replies
I am following the exact steps in connecting to an access database
http://wikihelp.autodesk.com/Infr._Map_Server/enu/2013/Help/0001-Getting_0/0016-Exercise16/0023-Conn...
and I get the following error when I test connection
An exception occurred in FDO component. RDBMS: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified.
Mapserver 2013, on Windows 7/64, I have the MS access 64 drivers installed.
any help is appreciated.
3 REPLIES 3
jackie.ng
in reply to: mfernandes
Microsoft Access Driver (*.mdb) is the 32-bit driver
Microsoft Access Driver (*.mdb, *.accdb) is the 64-bit driver
There should be a choice to pick between the two. It should be the second one.
- Jackie
mfernandes
BrilliantSmiley Very Happy
If I can now choose between the 32bit and 64 bit drivers,
does this mean that 64bit Map3D, Civil3D and Map server can now connect to MS office 32bit.
or do I still need to follow the proccess as outlined here
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18307898&linkID=9240697
to install the MS 64bit drivers.
jackie.ng
Your AutoCAD variant must use the Microsoft Access driver of the same bitness.
- Jackie
