Infrastructure Map Server Developer
*Giovanni
Message 1 of 5 (149 Views)
append new objects to sdf file
149 Views, 4 Replies
06-14-2005 03:00 AM
hi
i need to append new object to a sdf file
from a txt file where i have a polyline and coordinate of every point
there is someone function for this question
thanks Giovanni
*Andy Morsell
Message 2 of 5 (149 Views)
Re: append new objects to sdf file
06-14-2005 08:35 AM in reply to: *Giovanni
I would recommend you look at the .SDL format file which is the ASCII
equivelent of a .SDF. You may be able to manipulate (manually or
programatically) your text file to get the information into the required
format. You can then use SDFLoader to convert the .SDL to .SDF. There is a
switch with SDFLoader to append to the file rather than overwrite it.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
"Giovanni" wrote in message
news:4873961@discussion.autodesk.com...
hi
thanks Giovanni
Distinguished Contributor
Message 3 of 5 (149 Views)
06-14-2005 08:54 AM in reply to: *Giovanni
You could use the SDF COM Toolkit to accomplish this. I believe the Help for the Toolkit has examples to do this. If you get stuck just ask for help.
Scott
*Giovanni
Message 4 of 5 (149 Views)
06-15-2005 02:28 AM in reply to: *Giovanni
thanks very much
Giovanni
"Andy Morsell" ha scritto nel messaggio
news:4874369@discussion.autodesk.com...
Andy Morsell, P.E.
hi
thanks Giovanni
*Giovanni
Message 5 of 5 (149 Views)
06-15-2005 02:57 AM in reply to: *Giovanni
thanks very much
Giovanni
ha scritto nel messaggio news:4874385@discussion.autodesk.com...
help.
Scott
You are not logged in.
Ask the Community
