Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Zoomtoview in Fusion
9 REPLIES 9
Message 1 of 10
58064 Views, 9 Replies
HI
Want to use  ZoomToView(x, y, scale, refresh)  function in Fusion like its works in Ajax viewer calling this function by creating  Invoke Script.  Just cant this function working in Fusion.  Does someone have working script for it?
9 REPLIES 9
Message 2 of 10
fusion\layers\MapGuide\MapGuideViewerApi.js has a shim ZoomToView() function
- Jackie
Message 3 of 10
 I created Invoke Script and entered code below:
function ZoomToView(60000, 650000, 20000, refresh) {
    //var Fusion = window.top.Fusion;
    var mapWidget = Fusion.getWidgetById(mgApiMapWidgetId);
    if (mapWidget && mapWidget.isMapLoaded()) {
        var extent = mapWidget.getExtentFromPoint(x, y, scale);
        mapWidget.setExtents(extent);
Want to call this function in current mapframe so when I klick Invoke Script button then map are zoomed to desired location. I specified Target frame as "mapFrame".
Still problem get this working, I think I'm missing something.
Message 4 of 10
gluckett
Try:
    var Fusion = window.top.mapFrame.Fusion;
    var mapWidget = Fusion.getWidgetById('Map');
Message 5 of 10
in reply to: gluckett
I tried this code. Just copied this code to Studio invoke script window and specified target as mapFrame but still not working.
I add screenshot how its look like in Studo. I'm using open source Mapguide 2.5.
Message 6 of 10
gluckett
oh, if you are putting it in the INVOKESCRIPT, you don't need the "function"
just put this in your invokescript:
        var extent = mapWidget.getExtentFromPoint(60000, 650000, 20000);
Message 7 of 10
Code works but now i have new problem, pan function is not working after ZoomToview function.
Message 8 of 10
gluckett
If you want the PAN to be automatically selected after you zoom put this in the bottom of your INVOKESCRIPT:
 var panWidget=Fusion.getWidgetsByType('Pan')[0];
    panWidget.uiObj.setActive(true);
Message 9 of 10
Is it possible to add marker for this zoomtoview function? if can be done, may i know how to do that.
i have code below and it successfully zoom to the coordinate that i entered. but how do i show marker for the coordinate that i entered?
<html xmlns="http://www.w3.org/1999/xhtml">
<title></title>
<script type="text/javascript" language="javascript" src="../../layers/MapGuide/MapGuideViewerApi.js"></script>
<script type="text/javascript" src="proj4js-1.1.0/lib/proj4js-compressed.js"></script>
<script type="text/javascript">
//Proj4js.defs["EPSG:4326"]="+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs"
var source = new Proj4js.Proj('EPSG:4326');
Proj4js.defs["EPSG:3857"]="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs"
var dest = new Proj4js.Proj('EPSG:3857');
function ZoomToView() {
var latlong = document.getElementById('longlat').value;
var p = new Proj4js.Point(latlong)
Proj4js.transform(source, dest, p);
var scale = 2500.0003;//20000//15000//10000//5000//2000//1500
var mapWidget = GetFusionMapWidget();
var extent = mapWidget.getExtentFromPoint(p.x, p.y, scale);
</script>
<style>
h1{
font-size:20px;
font-family: "Calibri";
h2{
font-size:15px;
</style>
<body>
<div>
<h1> Search Coordinate</h1> <p>
<h2> Enter The Coordinate</h2> <p>
<input type="text" id="longlat" placeholder="In decimal degrees, eg. 102.xxxx, 6.xxxx"><br><br>
<button type="button" onclick="ZoomToView()">Search</button>
</div>
</body>
</html>
thx in advance
-nik-
Message 10 of 10
gluckett
If the Add the following to your INDEX.HTML for whatever Flexible Web Layout your are using:
<script type="text/javascript" src="../../../layers/MapGuide/MapGuideViewerApi.js"></script>
You can then use the DigitizePoint to put a point there.
For example:
DigitizePoint(OnPointDigitized);
