Infrastructure Map Server Developer
New Member
007dolenc
Message 1 of 6 (1,413 Views)
Zoom to selection
1413 Views, 5 Replies
04-21-2011 01:47 AM
In codebehinde or js I need to select object and zoom to selected object. I use in JS:
     function SetSelectionXML(selectionXml) {
          var Fusion = window.top.Fusion;
          var mapWidget = Fusion.getWidgetById(mgApiMapWidgetId);
          if (mapWidget && mapWidget.isMapLoaded() && selectionXml.length > 170)  {
              mapWidget.setSelection(selectionXml, true);
But I have problem with zoom to selection object, because is zoomig to different place.
In loadMap.php have I also change code to:
$minScale = "5000";
$maxScale = 'infinity';  // as MDF's VectorScaleRange::MAX_MAP_SCALE
if($minElt->length > 0 && $minElt->length > 1)
        $minScale = $minElt->item(0)->nodeValue;
Can you please help me?
Tenx!
Valued Mentor
gluckett
Message 2 of 6 (1,383 Views)
Re: Zoom to selection
05-01-2011 09:08 AM in reply to: 007dolenc
If you are using .NET you need to call a server side page sending the MAPNAME, SESSION, LAYER, and "where clause" to receive the XML of the selected features.
You then use Javascript to take that XML to select the features and zoom to it.
Javascript:
var mapWidget = Fusion.getWidgetById('Map');
 mapWidget.setSelection(myXMLReturnedFromServer, true);
the "true" actually zooms to the selected featue.
regards
gordon
Board Manager
Daniel.Du
Message 3 of 6 (1,284 Views)
08-10-2011 03:52 AM in reply to: 007dolenc
This blog may be helpful for you.
To Implement ZoomToSelection in Fusion Viewer MapGuide Enterprise 2011
http://www.cnblogs.com/junqilian/archive/2010/06/04/1751679.html
Daniel Du
Developer Technical Services
Autodesk Developer Network
Valued Contributor
swimming123
Message 4 of 6 (855 Views)
04-01-2013 10:28 AM in reply to: 007dolenc
In some of case, we want to "zoom to selection"; this "selection" is not by mouse click; it's by "enter an attribute value" or "by the calculation result which match some specific attribute column value". In this case we need an example how to use "setSelection: function(selText, ZoomTo) function, what is the input parameters?
Valued Mentor
gluckett
Message 5 of 6 (780 Views)
04-23-2013 07:03 PM in reply to: 007dolenc
You need the manually select the features programatically.  For example you want the road with an ID of 20
You pass the SESSIONID, MAPNAME, KEY (20), KEYNAME (ID), LAYER (ROADS)'
to: http://forums.autodesk.com/autodesk/attachments/autodesk/88/3201/1/GETSELECTIONXML.php.txt
but you should use AJAX (try jQuery - http://api.jquery.com/jQuery.ajax/)
once the XML is returned from the page, you can call the javascript call
The "TRUE" will zoom to selected (unless it is a point - AIMS 2013 and AIMS 2014 changed so it just pans to points now and doesn't zoom)
Active Member
francisco.rojas
Message 6 of 6 (499 Views)
09-06-2013 09:57 AM in reply to: gluckett
Also this post helps a lot, I tried it and it did works fine, this code is oriented to invoke a ZoomToSelection given by an external request from an External System, this post includes source code for either the Widget and Server Sive API like the example Gordon posted.
http://autodesk.typepad.com/beyondthebox/2012/09/application-integration-with-autodesk-infrastructur...
Regards.
You are not logged in.
Ask the Community
