When will market the new MapGuide Enterprise 2012, as well as mobile Viewer extention
MapGuide is now renamed Autodesk Infrastructure Map Server 2012 (check out some help here - http://wikihelp.autodesk.com/Infr._Map_Server/enu/2012)
When you first run Infrastructure Studio, you will have to log into the site with:
http://localhost/mapserver2012/
username: Administrator
password: admin
I have moved my MGP files over and they seemed fine during the migration, and most of my code seems good after migration from MGE 2011, I just had to tweak where the webconfig was located.
gordon
Gordon, we haven't gotten the 2012 yet, how is the mobile extension?
we've been playing around with the native openlayers support to do mobile touch navigation. seems to works quite well as is. so im just wondering what the mobile extension is bringing to the table.
Gordon,
System Requirements show: Microsoft® Windows Server® 2008 Enterprise R2. I was wondering if it would work on a Standard Edition. What is your setup?
Svet
The Mobile extension is a lot better than the generic openlayers one because it supports viewing attributes and scrolling though the records.
HI
I installed Infrastructure Mapserver 2012, I didnt found any useful information how to use mobile viewer. Can someone give advice how to setup map using Mobile Viewer extension?
Kajar
From the install DVD you have to install the TechnologyPreview setup.exe.
Once you have your can view the Mobile part:
http://localhost/mapserver2012/mobileviewer/index.html
parameters:
for example
?index.html?map=Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition&baselayers=osm.yahoo
regards
gordon
How in the world do you access this product?
My reseller cant find it and I called AutoDesk and the lady I talked to had never heard of it....
Strange, not the best reseller I think. But I'm working for reseller and there were no problem getting this at all. But in Autodesk website under products, its true, there is no information about Mapserver 2012, but this must be out, I have used this product one month allready.
I think you can download it through Subscription - wow if your reseller has not heard of it you might want to shop around.
Using Mobile Viewer its possible to get My Location in map, but its seems it only using cellular network of wifi network location. Gps location seems not working with this application. Does anybody got gps location working in Android based system.
