Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
WMS publishing problem, cannot load WMS Failed to get bands data.
3 REPLIES 3
10623 Views, 3 Replies
I published on IMS 2013 few layers to WMS. In "Infrastructure Map Server - Site Administrator" under "Configure WMS" I changed text-box Server name to relevant server name (in my case it is vtacnik
After I ran http://vtacnik/mapserver2013/mapagent/mapagent.fcgi?service=wms&request=GetCapabilities I get output saved in WMS.xml.
When you look this excerpt, there is: xlink:href="http://localhost:8008/mapserver2013/mapagent/mapagent.fcgi?"
<GetMap>
<Format>image/png</Format>
<Format>image/jpeg</Format>
<Format>image/gif</Format>
<DCPType>
<HTTP>
<Get>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://localhost:8008/mapserver2013/mapagent/mapagent.fcgi?"/>
</Get>
</HTTP>
</DCPType>
</GetMap>
 Is "localhost:8008" right? If not, why it was not change to server name "vtacnik" after I configured WMS?
I tried to add new layer into AutoCAD MAP3D, I was successfully connected and WMS schema was successfully loaded:
But when I checked layer to load it and click "Add to Map" I get error:
"Failed to get bands data.
Unable to connect to the host."
It is same error with Scheboygan data as well with my own data.
Where can be the problem?
Tags (4)
3 REPLIES 3
Go to Site Administrator - Configure (WMS/WFS)
Check that the server name does not have the port number.
I'm guessing the installer fails to update this part of the configuration if you didn't choose the bundled (Apache) configuration, where this configuration value would be applicable.
- Jackie
Hello Jackie,
Thank you for your answer.
I believe I changed settings of WMS/WFS to my server name without port number.
See print screen:
IMS_WMS_settings
Tags (2)
kalman_albert
You must restart server to update settings.
Albert
"Nothing will ever be as it was!"
