Infrastructure Map Server Forum
Welcome to Autodeskā€™s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Viewer API for Fusion
1 REPLY 1
swimming123
1800 Views, 1 Reply
I am using Fusion to do some customization of AIMS2013. Since I cannot use MapGuide Viewer API, I reference to MapGuideViewerApi.js, but this js file missing lots of functions, for example, I want to use "GetCenter()", "GetMapHeigh()t", "GetMapWidth()". Any similiar file I can call these functions? Thnak you.
1 REPLY 1
Daniel.Du
in reply to: swimming123
Firstly please refer to this document for more information of Fusion API http://wikihelp.autodesk.com/Infr._Map_Server/enu/2013/Help/0005-Develope0/0094-Flexible94/0101-Fusi...
Since all source code(JavaScript) of fusion is released with the product, you can dig into the source code itself to find the suitable method if some of them are missing.  C:\Program Files\Autodesk\Autodesk Infrastructure Web Server Extension 2013\www\fusion\lib by default.
Hope this helps.
Daniel Du
Developer Technical Services
Autodesk Developer Network
