Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Using Wheel Button to Pan
9 REPLIES 9
Message 1 of 10
2174 Views, 9 Replies
How would I go about making it so that clicking the middle/wheel button on the mouse will enable the pan tool while the button is held down. (Like in AutoCAD, Map3D etc.)
-Mike
9 REPLIES 9
Message 2 of 10
Look for the OnMouseDown(e) and OnMouseUp(e) functions in ajaxmappane.templ
That's where all the action starts and ends.
- Jackie
Message 3 of 10
Thanks for the reply.
I found the OnMouseDown(e) and OnMouseUp(e) functions in ajaxmappane.templ, I'm just not sure what to do with them. 🙂 I'm still kind of new at this.
My Autodesk reseller is telling me it can't be done in the AJAX viewer (which is what I'm using, forgot to mention that). Does she know what she's talking about?
Thanks again,
-Mike
Message 4 of 10
I can't see why it could not be done.
You are basically reusing the pan behaviour which is already implemented in the AJAX viewer, you just now have to hook that behaviour to a middle mouse click and release.
Unfortuantely, I cannot show you how to implement it, because I haven't done it myself, but I do have a high-level knowledge of the internals of the AJAX viewer to tell you that such a thing is possible.
Also, resellers usually aren't programmers and/or technically minded 😉
Message 5 of 10
wrote in ...
Jackie, you are starting to sound like Andrew D.
We are trying.
Murph
The world is not FLAT so why is your GIS data?
http://map3d.wordpress.com
Message 6 of 10
in the mousedown event, you have to check to see if it's the middle mouse button (these are different values for IE and FF...just google and you'll find this easy enough) then call the start pan function and on the mouseup, call the end pan function.
Message 7 of 10
david_roy
Hi all.  Was wondering if anyone had done this change successfully?  I'd really love to enable panning with mouse wheel.
many thanks
Message 8 of 10
Would also like to know the solution
thanks,
Message 9 of 10
in reply to: mitchellhastings1484
Firstly, Thanks Jackie for telling everyone where to look, this was pretty easy, and I'm not great at Javascript
I tackled this, and here is what I've got working...
Looks like the placement is everything to make sure you check for middle before left/ right
In ajamappane.templ....
in OnMouseDown(e) before the check for Left Button Click, check for Middle Mouse
function OnMouseDown(e)
    if(!PopupMouseDown(e))
        hidePopup(tbMenu);
        hidePopup(ctxMenu);
        hidePopup(infoMenu);
        parent.ForwardMouseDown(document, e);
    else
        return false;
    if(!mapInit)
        return false;
// NEW CODE BLOCK START HERE
    if(e.which && e.which == 2) //2 is middle button in W3C/Netscape Which
	StartPanning(e);
    else if(e.button && e.button == 4) //for ie, middle button is 4
        StartPanning(e);
// END CODE BLOCK HERE FOR MIDDLE Mouse PANNING
     if(e.which && e.which != 1)
        return true;
    else if(e.button && e.button != 1)//for ie
        return true;
Then in OnMouseUp(e)
function OnMouseUp(e)
    var x = e.clientX - mapPosX;
    var y = e.clientY;
    try
        e.stopPropagation();
    catch(ex)
        e.cancelBubble = true;
// NEW CODE ADDED HERE, BEFORE DIGITIZATION CHECK
if(e.which && e.which == 2) //2 is middle button EndPanning(e); else if(e.button && e.button == 4)//for ie EndPanning(e); // END NEW CODE
if(digitizing) { digitizer.MouseUp(e, x, y); return false; } if(isAlertShow) return;
I didn't test it out with other redlining or digitizing continuous commands.. ie pan will digitizing, but for my needs, just panning with the middle button adds a tonne of user experience if other things break.
Message 10 of 10
david_roy
Perfect!  does the trick, thankyou for posting.
