Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Use alias to mount the network drive
1 REPLY 1
ericsn.tang
530 Views, 1 Reply
Do anyone know how can I mount the network drive by using the alias in site administrator? I tried to create a new alias which the path is e.g. Z:\folder1, finally I cannot find the new alias in AIMS studio! The folder (Z:\folder1) must be able to access by the administrator. It is only work if the path is the local drives! Thanks.
1 REPLY 1
gluckett
in reply to: ericsn.tang
MapGuide/AIMS runs as a Service:  Start > Control Panel > Administrative Tools > Servies
In the Infrastructure Map Server 2014 - in the Log On tab, rather than using the "Local System Account", you will need to log in with a user that is:
1. A local Admin on the computer where AIMS is Installed
2. Able to see the network share where you store your files
Restart the AIMS service...
You can't use a mapped drive - you will have to use UNC path names in the alias.
\\MYCOMPUTERNAME\share1\folder1\
