We just upgraded to Infrastructure Map Server 2013 (on a brand new server). The data was copied from the old server, which was Mapguide 2012, to the new server but we're unable to see any of it in Studio. Do we need to do some sort of "import" function to be able to view the data. Any suggestions would be great.
Kristy
Do you have Feature Sources using aliased-flat files? Did you migrate the alias definitions as well, or have you re-pointed these aliases to the correct locations?
Do you have Feature Sources using a relational database like SQL Server or Oracle? Do these db connections work from your new server?
- Jackie
