Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Unable to find the Requester Raster Resource
1 REPLY 1
sarahjackel
2586 Views, 1 Reply
I am using Raster images in my MapGuide 6.5 map. It has been working for years, but just recently the rasters cannot be found. They have not been moved and the no changes have been made in the server admin tool.
I have tried moving the rasters to a different location, resetting the path in server admin and they still do not show up in the list of rasters in Author.
Has anyone seen this issue or know what I can do to fix it? I have attached an image of the folder containing the sid files, the server admin properties setting the raster path and the list of rasters (blank) in author.
thanks,
Sarah
1 REPLY 1
sarahjackel
in reply to: sarahjackel
Update:
When I point the raster search path to the MapGuide sample raster folder it works.
(C:\Program Files\Autodesk\MapGuideServer6.5\Projects\Sample_World\Raster) The image in that folder is a jpg.  Are SIDs no longer recognized?
I added a test SID to my raster folder to determine if there was an error with my original images, but it also did not show up in the raster list in MapGuide.
Do I need to convert my SIDs to jpgs?
