Show only
Search instead for
I have a shape file with an attribute defined as a short integer. I would like to display the attribute as a whole number, with no decimals, in the layer label. Is there a function that will do this?
Since there are no formatting functions or math functions available to you, create an expression for the label using 0 + columnname. This will effectively cast the result as an integer.
